adder I need your help
Old Aug 31, 2007 | 05:04 PM
ahittz24's Avatar
ahittz24
Default RE: adder I need your help
ORIGINAL: aode06
should of put the cap on as soon as the hot fluid starting coming out, whatever you do, dont shut that motor off
i had the same problem after my build, just drive it around and give it some time to get in all the knicks and crannies.
Alright I will try to burp the system again... without shutting the motor off I will go ahead and order the overflow tank too, obviously I need that
Old Aug 31, 2007 | 05:07 PM
aode08's Avatar
aode08
as far as the system being pressurized by the engine you should have coolant and oil mixed or a white cloud out the pipes
Old Aug 31, 2007 | 07:43 PM
my77stang's Avatar
my77stang
was i the only one to notice that if you do not have an overflow tank you need to leave the overflow hose open so that it can burp itself out onto the ground like every car in america did for about 75 years
Old Aug 31, 2007 | 08:04 PM
ddeaton66's Avatar
ddeaton66
+1 yup yup. then get a tank when you can
Old Sep 1, 2007 | 12:42 AM
ahittz24's Avatar
ahittz24
so I just got home to check it out after sitting another whole day. I have not started it in 2 days now and I took the rad cap off and smelled inside the radiator, it smells like exhaust fumes. I guess I will have to drain the oil tomorrow and see what it looks like.
Old Sep 1, 2007 | 03:27 AM
Justanother5.0's Avatar
Justanother5.0
If you're really concerned about exhaust in the cooling system, you can pick up a block tester, that will tell you for sure.
It sounds though that you still just have air in the system, and as mentioned above open up that overflow hose, you could just zip tie up a 1L water bottle or something somewhere and run the hose to it for the time being.
Old Sep 1, 2007 | 09:31 AM
5.0stanger's Avatar
5.0stanger
ORIGINAL: ahittz24
ORIGINAL: mattgt1000
what an *** kisser
ORIGINAL: ahittz24
1991 5.0 with a brand new 306 that I just built.
I got it all back together and the only thing that I am lacking right now is a coolant overflow tank. I put a vaccum plug over the overflow spout and put a hose clamp on it just for the mean time. I burped the system and filled it to the max and drove it for less than 3 min. didn't even get it to operating temp. pulled it back in the shop and looked under the hood. There is water everywhere on the driverside so I just left it alone for the night and figured I needed a new radiator cap anyways. I went and got a new cap and when I took the old one off, about a cup and a half of fluid spewed out (keep in mind that the motor is COMPLETELY cold.) I have a 3.8 taurus fan on a copper/brass 3 core radiator...
Any idea of what the problem could be?
I am seriously hoping that the system is not being pressurized by the engine,is there any way to tell?
no actually I just try to weed out information that isnt worth dick from people who have no idea what they are talking about. I have recieved credible information from him and therefore I trust what he has to say....
there are many people on here that i trust... but there are many more that I dont. if you had something credible to say besides "what an *** kisser" then maybe you would be one of the people whos information I would take heed of. I have nothing to gain by being on adders good or bad side, frankly... I couldnt give a rats ***... hes full of good info because he has been in many of the same situations as what we experience when we have problems and has the solution to many of thoseproblems....
There are lots of people that know stuff and have been in your situation. If you want an answer from only him, use the PM funtion.
Pull you cap off and let it run, then look for bubbles or rushing coolant in the radiator.
Old Sep 1, 2007 | 11:36 AM
ahittz24's Avatar
ahittz24
I drained the oil and I dont see any water in the oil. But it still doesnt explain the coolant smelling like exhaust...
Old Sep 1, 2007 | 11:49 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
ORIGINAL: ahittz24
It could be from sitting for a few hours while still being pressurized. I really wouldnt worry too much about the smell until you get that overflow situated. If you have to wait a bit for a bottle to come, do like stated earlier...Let it run to the ground or use a soda bottle to catch the excess, you cant just pinch it off completey.
Old Sep 1, 2007 | 12:35 PM
MadMan@TheWheel's Avatar
MadMan@TheWheel
And realize with no avenue for pressure release, this is a sealed system you ar dealing with now, if it builds pressure it will not just magically go away, that is why the system is designed with a vented overflow system. Which is why you either need a burp tube or puke can. Am I missing something? I have a tendency to be a little adhd
