Idle problem
Old Sep 2, 2007 | 01:36 AM
RED guy's Avatar
RED guy
Default Idle problem
Hey dudes whats up i am new to this forums and i just bought my 95 stang gt with 5 speed tranny.It have an rough idle problem and when i turn the steering wheel it turn off[:@].What could it be.please help.
Old Sep 2, 2007 | 12:17 PM
MikeVa's Avatar
MikeVa
Default RE: Idle problem
Clean your throttle body, MAF(use MAF or electrical cleaner ONLY), check voltage at your TPS. Should fall within .80 and 1.0 volts(Ignition on, car off) Sounds like your idle is WAY too low.
Old Sep 2, 2007 | 12:21 PM
5.0stanger's Avatar
5.0stanger
What does your car idle at?
Curlytop's Avatar
Curlytop
need a little more info. are you complete stock? or modified. does it happens while your driving or just parked? give more info.
Old Sep 4, 2007 | 08:25 AM
RED guy's Avatar
RED guy
the car is completely stock.some time it idle at800RPM normal and somtime go too down 400RPM and go up,and this problem appear only when parked.
Old Sep 4, 2007 | 08:46 AM
StangsR1's Avatar
StangsR1
u said when u turn the steering wheel the car turns off ?
Old Sep 4, 2007 | 08:55 AM
Curlytop's Avatar
Curlytop
Still need more info. However, i'll trystarting with thebasic cleaning your throttle body, maf, and filter. Also,inspect your wires and plugs. Last thingis also clean your injectors too. I would start there for now before messing with any adjustments and replacing any parts.
Old Sep 4, 2007 | 09:01 AM
samseed101's Avatar
samseed101
How far do you have to turn it before it stalls? A good step would be to check and clean your Idle Air Control. Carb cleaner is great for cleaning it. There are only two bolts holding it in, but it is rather difficult to get to the lower bolt in a 1995 GT. Once you get it off, just spray the hell out of it to remove and residue.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
