Some Kind Of Mount?
Some Kind Of Mount?
Having issues with the car shaking real bad, the motor is FINE. no leaks, it sits still when idling. Just replaced plugs, wires and cap and rotor and button. When revving it in high rpms, something definatly sounds loose. Some fluid was leaking behind the cats, it has to be something with the transmission.
I had a topic earlier but nobody replied so i opened a new one.
Any opinions?
Any opinions?
RE: Some Kind Of Mount?
Shot in the dark, but check your u-joints and overall driveline condition. Maybe the oil has nothing to do with it. This will eliminate drive line issues and narrow it down some. Just a thought
Is it around the clutch area? Because, its most definitely comming around there, i will have to get under it when i get off work.
It cancels out being the driveshaft or anything, because with the clutch engaged it still does the vibrating and loud noise when i rev it up high
ORIGINAL: dimebag
im thinking more on the lines of ur harmonic balancer
start it up... have some one rev it up for u... and watch the balancer... if its wobbly change it
jwog666
12-27-2021 08:09 PM
