Help with KOEO and KOER codes
RE: Help with KOEO and KOER codes
ORIGINAL: 95w.i.p
How do you test for an internittent failure?
ORIGINAL: Joel5.0
Need to start from scratch.....clear the codes, make sure memory is clear (run KOEO to verify), verify TPS output with a voltmeter, test drive it for 10 minutes, and rerun a KOEO and a KOER self-test. Those codes may have been logged in memory if you disconnected any of the sensors while the engine was running (= false codes).
lincolnshibuya
12-08-2015 04:37 PM
