Fuel delivery problems
hey i got a 95 gt with big problems. I floor it and power is good from about idle to 3500 rpms, after that the rms move reqlly slow and my speedometer barely moves. This happens in 1st through 5th gear. I replaced the cap and rotor, new wires, fuel filter, k&n airfilter. IDk wtf is wrong with my car it will bog down when im starting to move in first and then it will kinda take off. any body know???
RE: Fuel delivery problems
i have the same exact problem on the 95 i just bought and i have gone through all the steps you have.[/align][/align]pull some plugs, i bet they will be white like mine (very lean). as long as you think your fuel pump is good, then your need to clean/replace your injectors. mine were not even misting, i am ordering new ones from this place, cheapest place by half price. http://www.injectorwhse.com/servlet/Detail?no=2281 [/align][/align]good luck, ill let you know if mine is all better after injectors[/align]
so if its my cats do i need new ones or can i just punch them? fuel injectors were cleaned i ran somethin called injectr kleen . i had to disconnect the fuel lines and only run the cleaner. how i would i test my fuel pressure.? thanks
ORIGINAL: AdderMk2
could very well be... similar issue that I had with my 94 cobra
ORIGINAL: TTGreenSN95
could be clogged cats???
zanemoseley
09-06-2015 12:58 PM
