idle question
idle question
just got my car running and I'm having an idle issue. the car will run good than all of a sudden the idle will jump up between 1500 - 2000. everything on the motor has been replaced with new parts. i looked for vacuum leaks and ican't tell if there is or not. besides getting on a computer is there any other way to find out what might be going on?
RE: idle question
ORIGINAL: 89mustangfive0
check the voltage of the tps ( throttle Positiong sensor) with ke on engine off. the voltage should be between .997-.999
RE: idle question
ORIGINAL: Downset4130
RE: idle question
ORIGINAL: Texas5.0
I was having the same problem. I checked for leaks several times and could not find any. Took it my mechanic and he found several leaks on the lower intake. This caused tons of idle issues. I would take your car to a local garage and let them smoke the block. It may save you a ton of heartache and money.
trashxtrash
09-20-2015 10:49 PM
