Horse Power Estimate
I'm about to PCS (permanent change of station for you civilians) back to the states and when I get home I wanna stroke my 302 to a 331, put a E cam, AFR 185s, 30lb injectors and a 190lph fuel pump in it. What do you guys think the RWHP will be? I'm thinking somewhere around 300-315. I already have the GT40 intake, 65mm TB and 70mm MAM on it. Any thoughts or ideas are welcome. Thanks.
Steve
Steve
RE: Horse Power Estimate
ORIGINAL: ho85GT
iwould think around the lower side 300hp
im thinking over 300, between 325-350 wheel im thinking. could be wrong. THat car not stroked im guessing would make between 280-300 wheel some im guessing 325-350 wheel...good luck
ORIGINAL: anglia_stang
Steve
Steve
Oh yea the engine, depends on the cam and the compression of the Pistons. 10 to 1 compression with a good cam will bring you at least 350 hp from a stroked 302 to 331. Killer
i made 322rear wheel hp with a D.S.S pro bullit afr 185's rpm intake and a comp cam .512/.512 224/230 dur,and 112 lobe
with a whole bunch of stuff.....so i wouldn't see why that set up wouldn't make more being stroked.
don't use that E- cam! i did,and it sucked with those heads!
oh yeah use a 70/75mm t-body,and a 75/80 mass air too
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
