Have MPH gauge problem 10 to 15 off and bounces
I have a 1990 GT stock gears stock gauges problem is at low speeds the mph gauge bounces all over the place then past 30mph it goes anywhere from 10 to 15mph off.. What is the problem if ?? If I were to put the gauge cluster out of a parts car should that fix the problem??
RE: Have MPH gauge problem 10 to 15 off and bounces
Mine only bounces above 60, which is in reality 50 because the speedo is 10 off. I just watch the tach since the only reason I get that fast is for cruising, doesn't bother me enough to fix it
mines kinda the opposite mine bounces worse below 30-35 and smooths out above but never stops im guessing you prolly have 3.73 gears and if you have a 5 speed you should be at about 55 at 2000 if you want to correct your gauge get a 21 tooth speedo gear and it should fix you mph
musnicki
09-23-2015 07:11 AM
