'90 mustang LX 5.0 OBD1 Connecter?
RE: '90 mustang LX 5.0 OBD1 Connecter?
It amazes me at times what people will complain about. The scan tool is less than $30.00. It will check the codes, stored and while engine running. It will also run a cylinder balance test, check the plug wires, injectors and every solenoid and relay in the engine. Itcan also assist in finding problems that a code has not been generated for.
So I can see why you would not want to spend $30.00 to work on your car. Buy a box of paper clips and a case of beer and be pathetic like the rest of us.
ORIGINAL: Texas5.0
you can do the ole paper clip trick for free but if you just want to push a button on a scan tool then by all means spend the money but personally on these cars a scan tool is often a waste of money since you can't get a data stream to monitor signal inputs and outputs.
ORIGINAL: mjr46
shi@ like this messes up my flag sheet , ultimately , my paycheck[:'(]
