throttle body idel ?
Old Sep 17, 2007 | 02:40 PM
notchbackmatt87's Avatar
notchbackmatt87
Default throttle body idel ?
i just installed a stock throttle body on my 87 gt i changed it cause this one was powercoated dont ask me why i did not go bigger because my car is not modded to the point where it would make sense to get a bigger throttle body but anyways it went on good do i need to mess with the idel screw or no? i dont want to start the car and have problems
Old Sep 17, 2007 | 04:22 PM
notchbackmatt87
Default RE: throttle body idel ?
neone ?
Old Sep 17, 2007 | 05:59 PM
notchbackmatt87
Old Sep 17, 2007 | 10:42 PM
Black_Stalion_88's Avatar
Black_Stalion_88
start the car n see how it idols, just play with it if it dosent sound rite. just like tunein a carb.
Old Sep 17, 2007 | 10:43 PM
notchbackmatt87
ahh a newbie with some info thanks for your response to my simple question
Old Sep 25, 2007 | 09:45 PM
SkeetMaster's Avatar
SkeetMaster
ORIGINAL: Black_Stalion_88
just how superchargers and turbos work the same right? LOL
Old Sep 26, 2007 | 07:10 AM
creekrat's Avatar
creekrat
I'd suggest doing a base idle reset , just because the TB was not set to run with your car. Reset is a very simple process and will most likely make your engine run better than just putting it on and running it. It will let the computer better adjust A/F ratio and timing so you get the proper idle and the computer is not trying to make adjustments out of range.
Old Sep 26, 2007 | 07:48 AM
MikeVa's Avatar
MikeVa
Slap it on, check the TPS voltage, make sure that is correct. Then start her up. Adjust TB screw if necessary.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
