Trans 6spd
RE: Trans 6spd
The fith gear on the T-56 is overdrive...then 6th gear is like over-over drive...like .5:1. Also first gear is really low so you can get away with putting in 3.73s, or a bit higher, in the rear. www.ddperformance.com has a kit for $2500 that you can throw in.
RE: Trans 6spd
http://www.fordracingparts.com/parts...tKeyField=5955
That is what i was looking at trans ratios are 3.36, 2.07, 1.35, 1.00, 0.80, 0.62
it is better that stock t-5 its a closer ratio and im setting it up for street
Matt's 95 Stang
10-05-2015 07:16 AM
