Fuel Pump Question
Hi everyone this is my first post here. I have a 1990 Ford Mustang that I have a fuel pump question about. Before I bought the car about 2 years ago someone swapped in a carburated engine and installed nitrous. I have since uninstalled the nitrous and removed the malfunctioning Holley fuel pressure regulator. However, there is still a Holleyelectric fuel pump installed (I dont know exact specs). My question is now that the nitrous is removed can I convert back to a normal fuel pump? How hard would this be and what fuel pump would I need to buy? Thanks for your help.
No but I was assuming the high pressure fuel pump was for the nitrous. I was thinking I might be getting too much fuel into the carb from it now that I dont need that much and it isnt regulated causing the raw fuel smell? Should I leave it?
i would say you do have a high pressure pump in there if it did have a nitrous setup. you are going to probably going to get an adj. fuel press. reg. to make sure you arent putting too much in there.
