94 AODE to C4
94 AODE to C4
Hey there again guys. I have a question about changing the transmission in my girlfriends 94 GT from an AODE to a C4. Is it a direct bolt on? Or will I need to change the bellhousing, flywheel or driveshaft? I looked on the threads for a while here and couldn't find any info on swapping a C4 into an SN95. Thanks guys. Lowell
RE: 94 AODE to C4
You'll need a new ECU to do the swap. From what I've been told the transmission will bolt up to the engine but I know that the ecu won't let the engine run correctly without it controlling the shiftpoints of the transmission and since a C4 does not use the computer to control it, the engine won't run correctly near the shift points
