starting and idle problem
Old Feb 19, 2005 | 06:03 PM
BlackSN95's Avatar
BlackSN95
Default starting and idle problem
Recently my car has been very hard to start and also has been idling pretty rough. I've replaced the plugs, wires, cap, and rotor and still the problem continues. Someone told me it might be the ignition control module.
Old Feb 19, 2005 | 06:06 PM
Tims 88GT's Avatar
Tims 88GT
Default RE: starting and idle problem
Yes it could be that, they are cheep, do you have any mods?
Old Feb 19, 2005 | 06:51 PM
WesDe's Avatar
WesDe
It could be. Also check your coil. You might be getting a weak spark
Old Feb 20, 2005 | 10:35 PM
88GT40's Avatar
88GT40
mine has a hard time starting and it's idle is irratic i have found my problem it is a vacuum leak, you should spray carb cleaner all around vacuum line ends and also upper to lower intake manifold while engine is running and listen for idle fluctuation, if you hear the idle raise or fluctuate then you have a vacuum leak
Old Feb 20, 2005 | 11:17 PM
16FoxBody's Avatar
16FoxBody
check the TPS, could be your problem with the idle...g/l
Old Feb 21, 2005 | 12:18 AM
90GTRagtop's Avatar
90GTRagtop
Does it start more easily if you depress the gas pedal a little? If it does, start thinking along the lines of a vacuum leak or the Idle Air Control Valve (IAC). If your spark is weak, I'd kinda expect more problems at load & higher RPM t han at idle. If it's the IAC, sometimes they can be cleaned, but whenever I've had a problem one, I have eventually had to change it.
Old Feb 21, 2005 | 02:44 AM
bobby's Avatar
bobby
clean you MAF
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
fdnyems19
Aug 13, 2015 09:36 AM
