Swapping Rearends
RE: Swapping Rearends
Rear Disc Conversion Haha it is not all that hard to do but it would be wise to get a chilton book or some sort of mustang repair manual because you have to remember how the springs go together and such
I would pull the axles out and unbolt the brake backing plates. That way you don't have to disassemble the brakes or worry about bleeding the brakes either. You can keep the brakes on your car that you know work properly.
Springs wont cut you in half. Take out the shocks and lower the rearend and the springs pretty much fall out. I have heard the coil over strutstrying to remove the spring could do bodily harm if not done properly.But we dont have to worry about that on our foxes.
Matt's 95 Stang
10-05-2015 07:16 AM
