what is a good starting point when adjusting roller rockers?
what is a good starting point when adjusting roller rockers im using an e 303 cam and springs to match i know you use shims but how many would you start with and how would you know if you needed to add one or loose one???
RE: what is a good starting point when adjusting roller rockers?
That will help us get your geometry right once, and not have to ever worry about re-adjusting lifters, noise, broken studs, worn needle bearings, cam lobe wear, bent pusrods and other issues that involve improper valvetrain geometry.
The best part, is ITS CHILD PLAY[8D]
KEM Motorworks
08-14-2015 10:13 PM
