Timing?????
Old Feb 21, 2005 | 03:13 AM
91hatchgt's Avatar
91hatchgt
Default RE: Timing?????
I run 13* on 91 Octane.. It runs perfect, but I think I need a new distributor, After 118,XXX miles, I bet the shaft is a little worn.. What do you think?
Old Feb 21, 2005 | 03:16 AM
Ezrider's Avatar
Ezrider
ORIGINAL: bobby
ORIGINAL: luckythirteen13
i run 14* with 91. i can run 14* on 89 octane but on hot days it pings so i just run 91 all the time
wonder whyjust on hot day?
colder air is denser and less prone to pre-ignition aka pinging
bobby's Avatar
bobby
could be, and the bearing too, get an MSD pro billet [8D]
Old Feb 21, 2005 | 10:36 AM
brando5.0's Avatar
brando5.0
Yes, I unplugged the spout connector. Any other ideas?
Old Feb 21, 2005 | 10:44 AM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
usally that is a sign of a loose timing chain..get a new one..and replace it..that should fix it...
Old Feb 21, 2005 | 11:46 AM
brando5.0's Avatar
brando5.0
The slop that I was getting was caused by the rotor. It moved a little bit in the holder. I put a new cap and rotor on the car. The timing chain is tight. I just replaced the gasket the other day. Does anyone think that I should pull the distributor and move it a tooth or two, and then try to time it? 10* of adjustment is quite a bit of turn for leaving it on the same tooth.
Old Feb 21, 2005 | 01:54 PM
stanglx2002's Avatar
stanglx2002
i have mine a 13* and i run 87 octane and it runs fine
Old Feb 22, 2005 | 11:14 AM
pena8759's Avatar
pena8759
I am at 14* running 93 octane. And it runs strong.
Old Feb 22, 2005 | 02:28 PM
69mach1377's Avatar
69mach1377
ORIGINAL: brando5.0
I decided that I would check the timing on my Mustang, since I just picked it up a little bit ago. When I tried to time it, the light showed about 3* btdc, but moved around a little bit. I hooked up a compression gauge and found TDC on #1. The rotor points between 1 and 7 ( i cant remember exactly- the next one past 1 going counterclockwise- this is a H.O. motor). So should I pull the distributor and move it a couple of teeth so that it lines up right? I think the book said 10* ATDC is stock. How far can/should i go? Thanks for the help!
10* ATDC is stock?
Old Feb 22, 2005 | 02:29 PM
stanglx2002
it runs better when you advance it a little
