Timing?????
Old Feb 21, 2005 | 12:28 AM
brando5.0's Avatar
brando5.0
Default Timing?????
I decided that I would check the timing on my Mustang, since I just picked it up a little bit ago. When I tried to time it, the light showed about 3* btdc, but moved around a little bit. I hooked up a compression gauge and found TDC on #1. The rotor points between 1 and 7 ( i cant remember exactly- the next one past 1 going counterclockwise- this is a H.O. motor). So should I pull the distributor and move it a couple of teeth so that it lines up right? I think the book said 10* ATDC is stock. How far can/should i go? Thanks for the help!
Old Feb 21, 2005 | 12:36 AM
bobby's Avatar
bobby
Default RE: Timing?????
did you pull the spout conector out?
Old Feb 21, 2005 | 01:30 AM
Green5pt0's Avatar
Green5pt0
i advanced mine to 18* but its not cuz and dry. every engine is alittle differant and you have to see where your's likes it.
[IMG]local://upfiles/12913/2159DAD5A31A491481E9727D33BC0203.jpg[/IMG]
Old Feb 21, 2005 | 01:31 AM
bobby's Avatar
bobby
ORIGINAL: Green5pt0
18! what kinda fuel u runnin?
Old Feb 21, 2005 | 01:58 AM
dc_mann8's Avatar
dc_mann8
wtf.. u got some c 12 in there or what!!!, most can pull off a 14* mine is 13* on 92 octane
Old Feb 21, 2005 | 02:00 AM
Ezrider's Avatar
Ezrider
mine likes it at 12, it pings at 14 when i hit the upper rpms and i run 92 octaine
Old Feb 21, 2005 | 02:05 AM
89stanglx's Avatar
89stanglx
mine is at 14 and i run 92 octane
Old Feb 21, 2005 | 02:07 AM
bobby's Avatar
bobby
i can go 15 on 93 but i keep it at 14 to be safe
Old Feb 21, 2005 | 02:58 AM
luckythirteen13's Avatar
luckythirteen13
i run 14* with 91. i can run 14* on 89 octane but on hot days it pings so i just run 91 all the time
Old Feb 21, 2005 | 03:12 AM
bobby's Avatar
bobby
ORIGINAL: luckythirteen13
wonder whyjust on hot day?
