Automatic Stalling
Old Oct 4, 2007 | 07:20 PM
Stang_GT_91's Avatar
Stang_GT_91
Default Automatic Stalling
i recently had a tune up. they replaced a speed sensor in the transmission. they said it caused the engine to stall in idol. but now it is happening again. is it really the speed sensor or something else????
Old Oct 4, 2007 | 07:29 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Automatic Stalling
quite possibly it's not a transmission issue at all...could be an IAC valve malfunctioning
Old Oct 4, 2007 | 07:49 PM
notch5oh's Avatar
notch5oh
it could be a torque converter lockup solenoid if your car stalls when coming to a stop, but if it's stalling when you start up and it goes to idle then most likley an IAC issue
Old Oct 4, 2007 | 09:04 PM
shawnk007's Avatar
shawnk007
They ripped you off by selling you a speed sensor...
Old Oct 4, 2007 | 09:30 PM
aode08's Avatar
aode08
dont you have a 1991?
AOD is non electric guys
Old Oct 4, 2007 | 09:33 PM
shawnk007's Avatar
shawnk007
But it still has a speed sensor....
Old Oct 4, 2007 | 10:01 PM
black89gt's Avatar
black89gt
is has a manual speed sensor. not really a sensor though since sensors are electronic. his is cable driven.
Old Oct 5, 2007 | 09:02 AM
aode08's Avatar
aode08
ORIGINAL: shawnk007
yeah , that will not cause the engine to stall in an AOD, hell you can unplug that sensor with a good running car and it will idle fine.
Try cleaning throttle body and Idle Air motor with throttle body cleaner.
Commonly, the IAC(Idle Air Motor) is at fault and need of replacement.
If accompanied by lack of power, id replace the fuel filter.
Old Oct 6, 2007 | 03:20 PM
shawnk007's Avatar
shawnk007
ORIGINAL: aode06
ORIGINAL: shawnk007
I didnt say it would affect the engine....
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
wraith777
Sep 28, 2015 10:49 AM
