Do I need a hardened gear on my non roller distributor?
Does a roller motor require a special distributor gear?
I've got an '85 distributor and want to use it in a E7 roller motor from a '90 HO stang.
Thanks
Thanks
RE: Do I need a hardened gear on my non roller distributor?
You need the hard gear with the Ford roller cam.
Some 85s were roller also. I know the Crown Vics were and I believe 85 was the first Mustang to get them.
Are you sure the 85 is not a roller? Truck engines were not.
if the dizzy is out of a non roller engine take the gear off your roller dizzy shaft and swap them.. I did it and it worked fine...I believe the dizzy shafts are the same size ..pending what dizzy you have... if it has play when to swap and slides on way to easy then go buy a steel gear
You could leave the gear alone and uprade your camshaft with a piece from Comp. Their hydraulic roller cams are compatable with the early iron dist. gears.
Something to think about...
bradleyb
11-27-2015 07:50 PM
KingRando
10-02-2015 08:06 AM
