muddy brown coolant
Old 10-12-2007, 10:38 PM
THammy
THammy's Avatar
Default muddy brown coolant
Hi went to flush and change the coolant in a car I just purchased and when I opened the radiator cap it was a brown muddy mess. From what I have heard with this situation the previous owner must have mixed green and orange coolant together. the reservoir was empty. So I obviously need to flush it. my question is can I do a normal flush or did this damage any of the cooling system. It has an aluminum radiator and has aluminum heads. I have only driven the car once and it did not show any signs of overheating. Thanks in advance
THammy is offline
Old 10-12-2007, 10:45 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: muddy brown coolant
go to an advance autoparts, get the prestone flush kit, completely drain your cooling system and run water though it for a while.... you need to wash all the crud out of it
AdderMk2 is offline
Old 10-12-2007, 11:47 PM
stang8689
stang8689's Avatar
Its easy to do butI would replace the hose you cut cause the prestone thing will leak down the road
stang8689 is offline
Old 10-13-2007, 08:06 AM
THammy
THammy's Avatar
Thanks I am going to do it sunday.
THammy is offline
Old 10-13-2007, 12:05 PM
creekrat
creekrat's Avatar
Sounds like a bad head gasket! Combustion gasses entering the coolant system causes nasty muddy looking coolant. Do a coolant system pressure check and cyl compression check to find out for sure.
creekrat is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
flash_xx
10-16-2015 07:23 AM
wraith777
09-28-2015 10:49 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: muddy brown coolant
