Water Pump Question
Old Oct 12, 2007 | 11:44 PM
stang8689's Avatar
stang8689
Default Water Pump Question
Need a new ones cause mines leaking, I was lookin at the Weiland polished aluminum high flow for $135. Anyone know if its any good. Also its my first time changing a water pump, does anyone have any pointers.
Old Oct 13, 2007 | 12:24 AM
cleanfitty's Avatar
cleanfitty
Default RE: Water Pump Question
Be careful when removing the bolts so they dont break in the block/timing cover, and also be careful when pryingthe old pumpoff the timing cover so that you don't break the water jacket seal between the block and timing cover, cause that can cause some nasty leaks thet will require a new timing cover gasket.
If the bolts are good, you are in great shape. If not they can be pricey to get from the dealer.
Old Oct 13, 2007 | 08:44 AM
stang8689's Avatar
stang8689
What kind is everyone running
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
9550
Oct 26, 2015 05:01 PM
96stang3.8
Sep 10, 2015 06:42 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
