map light woes...
One screw on the left is hot and the screw on the right is ground. In my 87 the wire runs to the fuse box on number 8 I believe.
It is a 15 amp fuse. It also is the fuse for the dome light. So if your dome light is working then your fuse is good and your problem lies in the hot wire under the headliner. The wire on mine ran across the passenger side under the visor and down the "A" pillar. Then across the under the dash.
Good Luck,
Roger
Good Luck,
Roger
Are you getting juice to your map light? My first map light went bad at the little pin switch. I took a soldering iron and touched the plastic nibs that hold the switch assembly in place and got it to work again.
I think this might help you out. Map light info is in the bottom left corner.
http://www.veryuseful.com/mustang/te...nt-Cluster.gif
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
