finally getting an 8.8 rear
Old 10-25-2007, 08:11 PM
HACKGT350
HACKGT350's Avatar
Default finally getting an 8.8 rear
ok so im getting an 8.8 rear tomorrow for 75 bucks and im doing a full overhaul on this thing only thing is the gears im going with 3.73's now where should i get them? i was thinking ebay specials wont hold up very well and to just get some off summit or something what do you guys say?
HACKGT350 is offline
Old 10-25-2007, 08:24 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: finally getting an 8.8 rear
http://www.buyfordracing.com/shop/index.php?cPath=3_37
PRO50SC is offline
Old 10-25-2007, 08:28 PM
86 5.0L
86 5.0L's Avatar
plus one
are you getting just the gears? or installation kit too?
86 5.0L is offline
Old 10-26-2007, 06:33 PM
HACKGT350
HACKGT350's Avatar
thank you bernie. no im not just throwing the gears in im gunna get the shim bearing kit and rebuild trac lot kit. i picked up the rear today its still sitting in the hatch of my car till i can drop it off at work on tuesday its gunna take like 2-3 months to get all the parts and install it im so pumped over this
Old 10-26-2007, 07:05 PM
runsrich
runsrich's Avatar
I would buy the new carbon fiber posi clutch plates from ford, they are supposed to last longer along with a new pinion bearing thats been honed out for a slip fit to set the pinion depth. Iwould set thebacklash at .008
runsrich is offline
Old 10-26-2007, 09:31 PM
HACKGT350
HACKGT350's Avatar
ORIGINAL: runsrich
thanks but i already know how to set the pinion depth and backlash. i also hate to inform you but you can preset the backlash like that all ring and pinion sets are different so the depths and backlashes will never ever be the same
Old 10-27-2007, 08:49 AM
stang8689
stang8689's Avatar
Good luck and have fun
stang8689 is offline
67LimeCoupe
09-30-2015 04:46 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
Quick Reply: finally getting an 8.8 rear
