missing from 700rpm to 1000rpm.....
I noticed after its rained my car is missing from about 600rpm to about 1000rpm, what could be causing this, It goes away after 1000rpm, whats the problem? Also when it does that the idle goes down to 600rpm, and when it idles it jumps back and forth between 600-800rpm it idles wierd? what could be causing this?
RE: missing from 700rpm to 1000rpm.....
ORIGINAL: MurPHy
Hahhahaha. Good one. ......Oh wait, you're serious. Pffff.
Sounds like the IAC valve is screwed up. You might wanna take a look at that first.
ORIGINAL: Aliate X
stock cam?
stock cam?
I can see your new here, and I can also see your off to a bad start.
ORIGINAL: Aliate X
Dip**** I was asking if he had a stock cam.
ORIGINAL: MurPHy
ORIGINAL: Aliate X
stock cam?
stock cam?
[sm=exactly.gif]
ORIGINAL: Aliate X
ORIGINAL: MurPHy
ORIGINAL: Aliate X
stock cam?
stock cam?
I don't visit here very often anyways, I don't really give a ****.
ignition module, or water inthe cap and rotor... im 99% sure this is ur problem, ford are NOTORIOUS for having problems with water getting in the cap and rotor. go buy new ones, shouldnt cost much at all, that should definetly solve the problem
ORIGINAL: MurPHy
ORIGINAL: Aliate X
stock cam?
stock cam?
when was the last time the spark plug wires were changed?? bad wires will act up when it rains or in really high humidity. also make sure that you use the silcone dielectric grease on the wire boots to seal out moisture. you can get this at any auto parts store.
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
