Finished fuel pump - New Problem..
#31
RE: Finished fuel pump - New Problem..
ryan, disconnect the fuel line from your filter, run 4' of 3/8" fuel line from the filter, to a gas can... or three gas cans.
find the DLC connector under the hood (passenger side, behind the strut tower)
Ground the fuel pump trigger pin in the DLC and the fuel pump will turn on while the ignition is in the ON position. Use the pump to empty out the tank into the gask cans.
then get the seals you need from Advance Autoparts... we stock that stuff
#32
Thanks a lot Adder, that's a ****in awesome idea...
I used new seals though, I don't understand why they'd be leaking. Does anyone know where I can get a new lock ring? the one 50resto sent me didn't fit and Advance says they cannot get me one [&:]
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
