pre-detonation/ping
#21
RE: pre-detonation/ping
A quick check of the MAF senor and throttle positon senor may help with the lean code. The filments of the senor in the MAF housing need to be clean( I think you need a T-20 bit to get it out). I would also run some complete fuel system cleaner through it, maybe even back-to-back tanks. Also, change the fuel filter, like mrj mentioned, it probably needs doing anyways. My 94 pinged on premuim gas as well, cleaning the MAF helped out tremendiously.
#22
When replacing the fule filter, do I need to relieve linepressure at the schrader valve? of can I just wrap a rag aroung it totry and contain the fuel+remove & repalce the filter? Thanks for all the help/suggestions so far.
nick
nick
#23
I usually let the car sit for a couple hours before I do the fuel filter that way the pressure has all bled off. Even still, when you pull the fuel line off, some fuel will run out, but nothing spectacular. I just hold it with a rag while I pull the old filter out, and put the new one in. Takes like 5 min to do the whole thing.
