During WOT, Stops at 4k!
Old 11-03-2007, 12:07 PM
Black95MustangGT
Black95MustangGT's Avatar
Default During WOT, Stops at 4k!
This only happens on the highway because usually thats where i get on it more often. Well this is the story, getting on I-95 (highway) i usually keep it at 3k then gun it. Runs smooth through 2nd gear, goes into 3rd then usually once it hits 3800-4000 rpms it just stops, and i have to shift it in order for it to pick up again.
I gave the car a fresh tune up since this started happening. The synchros in my tranny are going, i have no idea if that could deal with anything. Could it be my driveshaft? and is there anyway i can test it to check it out?
Black95MustangGT is offline
Old 11-03-2007, 04:54 PM
89TripleWhite
89TripleWhite's Avatar
Default RE: During WOT, Stops at 4k!
Stops like maybe its the cats? mine did the same thing, i have a t-5 syncs are kinda gettin worn....but i had a clogged cat and an empty cat on a stock system (i bought it used and abused) so i changed to a hiflow X pipe and headers, so my upper cats were eliminated. and my power is smooth throughout, i couldnt even go past 4 before, it would act real sluggish and kinda die out after after, if i could even get it to go that high
89TripleWhite is offline
Old 11-03-2007, 07:11 PM
Black95MustangGT
damn bro, you actually could be right haha. I really didn't think about that.
Was running rich a couple weeks ago, gave it a tune up and it solved that problem. still smell a tiny bit of fuel..probably is my cats.
If it is my cats, anyway to fix them without buying a new mid pipe? I'm moving to Florida and getting a 96 cobra and i am goin to make this my track car so as of right now im just going to save my money up. Only option is to probably gut the cats right?
Old 11-03-2007, 08:26 PM
aode08
aode08's Avatar
ORIGINAL: Black95MustangGT
run a electric plumbing snake through them and dump all that white and black cluttered garbage away.
I usually block off the tail pipe with potatoes and use the wet and dry vac to remove the clutter, the snake left.
aode08 is offline
cr620
10-03-2022 10:18 PM
4cylinderplus2
10-09-2020 07:45 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: During WOT, Stops at 4k!
