need stock cam specs
RE: need stock cam specs
SD cam @.050" = 210/210 @115 LSA = Int = -10/40 Exh = 40/-10 with 115 ICL
SD cam @SAE .006" = 266/266 = @115 LSA = Int = 17/69 Exh = 67/19 with 115 ICL
FYI the xx/yy is open/close degrees ...and the above numbers could be anywhere when installed due to tolerances.
EDIT:....NM....too late.
uberstang1
09-20-2015 06:42 PM
