Help reading carb spec sheet
I just got the build sheet for my carb and i have no idea what im lookin at. it may as well be in chineese. Here is the way it breaks down.
XC
Main body desc. 780 ADJ SEC BT
Inlet 60 LinkageST
Booster D/Desc 4785EM 28-3p 31uax28-3s
metering block# 11180 FL 451-451a
AF-WD16-40 NS 120
P/S Pump 30/30 Plate# 215-172
P/S sqrtr 40/40
Primary Venturi Specs Secondary Venturi Specs
Baseline lean-rich baseline lean-rich
Main Jet 74 71-77 84 80-86
Hi Air 36-10 40-32 3640-32
idle air 70-10 90-60 70-10 90-60
idle feed 33p33p
PV feed 5543
PV 6.5 PL
PRI JET 74 SEC JET 84
Static Draw Test
200 755 102
250 887 161
300 985 194
XC
Inlet 60 LinkageST
AF-WD16-40 NS 120
P/S sqrtr 40/40
idle feed 33p33p
PV feed 5543
PV 6.5 PL
Static Draw Test
200 755 102
250 887 161
300 985 194
RE: Help reading carb spec sheet
ORIGINAL: hillbilly pony
XC
Inlet 60 LinkageST
AF-WD16-40 NS 120
P/S sqrtr 40/40
idle feed 33p33p
PV feed 5543
PV 6.5 PL
Static Draw Test
200 755 102
250 887 161
300 985 194
XC
Inlet 60 LinkageST
AF-WD16-40 NS 120
P/S sqrtr 40/40
idle feed 33p33p
PV feed 5543
PV 6.5 PL
Static Draw Test
200 755 102
250 887 161
300 985 194
mjr it is the sheet for the engine in the sig. I just dont really know what the numbers mean. I had to fill out all of this stuff with pro systems when i ordered it so i have to assume it is good. Can you give me a little learn'n?
uberstang1
09-20-2015 06:42 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
