someone help (adder u might know the part#)
Old 11-12-2007, 09:52 PM
blk40th
blk40th's Avatar
Default someone help (adder u might know the part#)
ok need big help, i went to go buy rotors and autozone doesnt sell the right ones for 94-95. i have a 5 lug conversion with the whole rotr and hub as one. does any one know the part # i need to order, or is there a different year i should order for?
blk40th is offline
Old 11-12-2007, 10:32 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: someone help (adder u might know the part#)
ORIGINAL: blk40th
cobra or GT rotors... and are you using 94-95 spindles?
AdderMk2 is offline
Old 11-13-2007, 12:34 AM
SPE926
SPE926's Avatar
I think he means the frpp front rotors, ask the parts guy for rotors for an 84-86 mustang svo
SPE926 is offline
Old 11-13-2007, 08:36 AM
blk40th
blk40th's Avatar
they were already on there when i bought the car. i think it might be the 92 lincoln rotors. it still has the 88 pads and calipers, so i would say thats still the 88 spindle also. the hub is big in the center and knocked the center of my rim out so i think its that big lincoln hub in the center.
blk40th is offline
Old 11-13-2007, 10:30 AM
ACE
ACE's Avatar
1987 LincolnLSC front rotors are all as one and need to chew the rim up to make fit so thats what it sounds like you have!
ACE is offline
Old 11-13-2007, 11:18 AM
blk40th
blk40th's Avatar
a late 80's lincoln mark series will work right?
blk40th is offline
Old 11-13-2007, 11:43 AM
ACE
ACE's Avatar
From how you explained it, yes it should.
ACE is offline
Old 11-13-2007, 01:03 PM
SPE926
SPE926's Avatar
the lincoln and the svo rotors are the same exact thing why your at it get the front calipers for an svo as they are bigger than the stock ones and will be an improvement over stock
SPE926 is offline
Old 11-13-2007, 04:11 PM
blk40th
blk40th's Avatar
ive been having the worst time trying to get these rotors. ordered them to come in for tomorrow and i hope they are right. i wish i had the money to do calipers right now. will they bolt up to the 88 bracket and brake line. um doing the wheel bearings and lines also. rhis has to be the worst day tho. i found out my head gaskets are leaking now.
blk40th is offline
Old 11-13-2007, 04:33 PM
Dave5point0
Dave5point0's Avatar
That sucks. I'm in a crappy situation with front rotors too, my 5 lug was done before i bought it too, i'm 99% sure my rear end is complete from a 95 because of the abs speed sensors and wiring attached to it, but as far as my fronts go, i have no idea, and i think i have a bad wheel bearing because it moans with weight transfer when i turn, but i don't know what wheel bearing to buy because i don't know what spindles/hubs/rotors are in the damm thing. SUCKS.
Dave5point0 is offline
Quick Reply: someone help (adder u might know the part#)
