lincoln drivetrain will it work?
i have an 84 coupe roller that i am working on and have been offered an 89 town car for the drive train really cheap
will the 8.8 rear work?
any differences in the aod in a town car and the aod out of a fox?
will i need a custom drive shaft?
thanks for the help
thanks for the help
RE: lincoln drivetrain will it work?
It will work if it has quad mounts for theshockwhich it should if its a 8.8 and i believe the left or right axle is the same on the lincoln as the mustang if im not mistaking. you probably will have to get a different drive shaft due to the length of the lincoln and and due to the transmission in the stang. I THINK butwith any if little modifactions it will work.
Engine and tranny should work fine, you will only need a mustang drive shaft, the town car rear end as I recall will not direct bolt up I know the rear from the Mark/LSC will fit but not the towncar. You might however be able to use the rear disc brakes in combination with the correct size 8.8 and axles.
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
