Weird Idle
Old Nov 16, 2007 | 04:11 PM
65coupe88hatch's Avatar
65coupe88hatch
Default Weird Idle
finally got my 1986 5.0 gt running, but my idle seems to fluctuate between 1000, and 700 rpms, i cant figure it out, ive put new plugs in it, but havent changed the wires or distributor they look to be brand new thats why i didnt touch them, vacuum line off somewhere? i really dunno whats causing it anything i should look for?
Old Nov 16, 2007 | 04:29 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Weird Idle
have you tried to clean the IAC motor/valve????
Old Nov 16, 2007 | 05:40 PM
65coupe88hatch
No, how do you go about doing that, and what ya use?
Old Nov 16, 2007 | 05:57 PM
86GreenMachine's Avatar
86GreenMachine
Srpay the bitch bown with carb/throttle body cleaner.Also check your TPS voltage.It should be between .49 - .99 at closed throttle.
Old Nov 16, 2007 | 07:04 PM
slickshift's Avatar
slickshift
Welcome to the World of the SD 5.0 Wandering Idle
It can be caused/fixed by many things...or not at all
It's as common as the 5.0 tick or the Fox Lean...and just as elusive
It could be:
TPS out of wack/failing
AIC needs cleaning or is failing
TB gunked up and needs cleaning
CTS failure
Could be fixed by:
Cleaning the above
New TPS
New AIC
New CTS
New TB
Adjustable Fuel Pressure Regulator
(?...I don't know why but it worked on one)
Or some people have reported success with a Ford part mentioned in this TSB from Ford:
http://www.mn12performance.com/mn12-...-7.pdf#search=
(yeah...it's common enough to have a TSB issued)
I don't have first hand knowledge of this one, but have reliable sources that had success with it
Old Nov 16, 2007 | 08:08 PM
mighty90's Avatar
mighty90
Nice post slick, added that pdf to my harddrive.
Old Nov 16, 2007 | 08:14 PM
white93pony's Avatar
white93pony
i would check your tps set it at .90-.95 .49 is too low and check the above mentioned stuff^^^ and clean as necessary
Old Nov 17, 2007 | 08:03 AM
65coupe88hatch
ha...so i dont know what any of that stuff is...anyone want to explain
Old Nov 17, 2007 | 11:14 AM
dimebag's Avatar
dimebag
what kind of cam?
Old Nov 17, 2007 | 11:16 AM
65coupe88hatch
stock
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
mungodrums
Sep 28, 2015 10:54 PM
MacSerio
Sep 27, 2015 01:05 PM
