dashboard swap how hard?
RE: dashboard swap how hard?
While you're that close, may as well put a new heater core in too. You'll only be like an hour, tops, away from doing it. Might not be a bad time to do a clutch quadrant too. With all the stuff out of the way you'll be able to see whats going on better (access will be about the same though). Then you'll have the 2 worst fox body jobs done.
Here is an Ace tip, take it all out and when you put it back together, only put half the bolts necessary in it so when you take it out to do the heater core its quicker! hahaJust kidding! It is not that hard at all to do just very time consuming!!
ORIGINAL: mudvayne1
It's not really that hard you just have to be really careful not to break those plastic pieces. Keep track of your bolts and buy yourself a case.
I recommend Corona or Molson for this type of job.
Matt's 95 Stang
10-05-2015 07:16 AM
