torque?
i have pedistal roller rockers. one of my cylinders does not fire or hold compression due to a burnt valve. the roller clicks like a *****. anyone know the torque spec or anything around it. im about just to take them out. should i just put them down as tight as possible?
ORIGINAL: 84conversion50
Yeah, with the valves closed you finger tighten the capscrew until 0 lash(no clearance between the valetrain parts, but the lifter plunger has not compressed) and then the torque of 18-25lb-ft should occur between 1/4 to 1 full turn of the capscrew. If the torque occurs before 1/4 turn after 0 lash you need longer pushrods, if the torque occurs after 1 full turn you need to shim the pedestal.
ORIGINAL: 67mustang302
LivingInThePast
Sep 16, 2015 12:20 PM
