Clutch?
Old Dec 7, 2007 | 08:50 PM
mustangmdr's Avatar
mustangmdr
Default Clutch?
Should my throwout bearing be in constant contact with the plate fingers?Because there is nothing to bring the bearing back from touching the fingerson my transmission like a spring or magnet.So Im guessing on my 91 thats the way its supposed to be? No matter how I adjust it the bearing seems to be touching atleast a little bit.
Old Dec 7, 2007 | 09:47 PM
92GreyGT's Avatar
92GreyGT
Default RE: Clutch?
Yes it is designed to be in constant contact with the pressure plate fingers. If you adjust it far enough back to not be in contact I doubt you will be able to get it in gear.
Old Dec 10, 2007 | 10:51 AM
Jfsram's Avatar
Jfsram
Default RE: Clutch?
I think the bearing off the fingers is for older cars. Not sure if it's the quality of the bearings back then but they were meant to be not turning when your foot is off the pedal.
My Ram has a hydraulic clutch and it's also leaves the bearing in constant contact with the fingers.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
