is it possible to get an alternator that is too powerful?
RE: is it possible to get an alternator that is too powerful?
Yea you will be fine with you batt. but look at the specs on the alt befor you buy it , the big amppers dont make mutch power at 2000 RPM that is crusing speed . and with under drive pullies it is worse . I think the stock 80 ampper is fine they make most of the amps at or below 3000 rpm . and they can hold up at 6000 RPM , and will run most steros amp the big 160 amp 1 wire alts are for race cars that spinn 7000 to 8000 rpm wit out blowing the alt up you stock EEC-4 system has a rev limiter at 6250 RPM and the big race alt would just be a waist of money
If you realy need more amps try to get a alt that is for a truck or a RV . they are just like the stocker and make nost of their amps below 3000 rpm . the race alts are not reliable on the street an will more offten than not let you down . It does not matter standert or reverse spin they work in either direction .
use one from a same-year F-150? just wondering cause i was gonna look into a new alt. pretty soon. i've got underdrive pullies and everything just dims out in idle.
THE F-150 CAME WITH A 100 AMPER AS A OPTION UP GRADE SO LOOK OUT .
it is bigger than the mustang alt and wont fit in the stock bracket . the 80 & 60 ampper in the bronco to F-350 are the same as the one in the cars . The base line F- truck came with a 42 amp alt and is olny gool to run wippers , lights, iggy and the AM raido that came with the truck .
You can't go too big on an alternator, it will only make the power it needs to, but if you're drawing alot from a stereo, electric fan, etc they recomment you use higher capacity power cables to prevent a fire.
-Green5pt0
-Green5pt0
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
