timing cover bolts
RE: timing cover bolts
Don't order the timing cover/water pump ARP kit from Jegs... it said for a 302 with aluminum timing cover. When I got it, the bolts didn't look anything like what the stock ones did. Wrong lengths! Worthless... so I sent it back. Just go to Lowes and get the ones you need like I did. I got stainless ones and spent a fraction of what the junk ARP kit costs.
Oh, and a member and a moderator on here (won't mention their names) were supposed to be helping me get some water pump bolts, but neither came through for me. So I solved the problem myself and bought those bolts at Lowes too and located the double ended stud ones ata local junkyard.
um... no, not too sure... summit maybe? theyll prolly be afr, and expensive.
id go to lowes/homedepot, and get bolts/nuts... they might even just have studs... start them, throw a nut on... you know the deal... just get creative.
if you end up ****ed, i can see ifi have a full set here... i have a box of bolts off 3 motors... so i very well may have timing bolts left...
waid302
09-14-2015 11:19 AM
YoungStangsMan
09-05-2015 07:01 PM
