rear end question
Old Dec 31, 2007 | 10:29 AM
green95GT's Avatar
green95GT
Default rear end question
will a rear end off a fox body fit my 95???
Old Dec 31, 2007 | 11:24 AM
white93pony's Avatar
white93pony
Default RE: rear end question
yes it will fit but you must change the axles, brakes, etc pretty much you will use the housing and center unit.
Old Dec 31, 2007 | 11:36 AM
ewgoetz's Avatar
ewgoetz
Think everything should fit minus the brakes. I had a expanded view of the rear form a dealer that had all the part numbers and the page had it listed from the 80's till 97 I think.
Old Dec 31, 2007 | 11:45 AM
white93pony
yea but the axles are different on fox cars they are 4 lug and they are about 1/2 inch shorter on each side.
Old Dec 31, 2007 | 01:33 PM
green95GT's Avatar
green95GT
so how long and how hard is it to change out the axle, brakes i know how to do but idk about the axles is it complicated or not
Old Dec 31, 2007 | 01:36 PM
ctgreddy's Avatar
ctgreddy
shouldnt be very hard at all.
if you have a sn95 right now all you need is axles, you can use ur stock brakes.
and you can buy aftermarket axles for as little as 90 a pair or 200ish a pair for the nice mosers.
Old Dec 31, 2007 | 01:38 PM
green95GT's Avatar
green95GT
ORIGINAL: ctgreddy
So i can't use my axles i have? i have to get new ones?
Old Dec 31, 2007 | 01:43 PM
ctgreddy's Avatar
ctgreddy
if the axles are from an 8.8 and the splines on the ends are in good shape, then you will be good to go.
i wasnt sure if you had an 8.8 or 7.5, and i dont think a 7.5 axle is the same as a 8.8
but like i said, if you already have an 8.8 then you will have everything you need as long as the axles arent damaged.
GimpyHSHS
Aug 29, 2015 06:30 PM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
