CLUTCH PEDAL WIRING????
Old 01-01-2008, 11:21 AM
sofob0909
sofob0909's Avatar
Default RE: clutch pedal wiring????
im looking to only have it jump the neutral safety switch when i want to remote start. So the relay is my choice. I need to know which wires though. and how to test them to be sure, I am also putting in a switch that will cut the ground for the remote start if it is in gear. These two switches should stop any "jumps" or "starts in gear". Which wires and how do i test for them?????
[align=left] [/align]
sofob0909 is offline
Old 01-01-2008, 11:22 AM
Tony71502
Tony71502's Avatar
Does the starter have enough torque to move the driveline when the car is in gear and parked?
Just know that to make this work you would have to leave the car in neutral when u want to remotely start it. I dont know about you but even with new parking brake equipment... I dont trust it. I leave my car in gear all the time.
Tony71502 is offline
Old 01-01-2008, 11:27 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: sofob0909
[align=left][/align]
How? The trans is completely mechanical, how do you plan to accomplish that?
PRO50SC is offline
Old 01-01-2008, 11:28 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Tony71502
Yes, it does!
PRO50SC is offline
Old 01-01-2008, 06:43 PM
sofob0909
sofob0909's Avatar
im making switches that will open the ground when the shifter is in gear.
Old 01-01-2008, 08:49 PM
93nitrousLX
93nitrousLX's Avatar
The way to do this right would involve installing an additional safety switch into the shifter I could see this easily on a hurst with stops.... And then a very simple relay to by pass the clutch safety switch... It should be the one that is physically on the clutch pedal and there should only be 2 wires... One in and one out.... (I cant remember right now if its normally open or normally closed... If its open just have your relay close or open the ckt as the case may be.... But you can use the same path in parallel to your shifter switch... (it may be more work then its worth...) or if you are going to install a switch on the shifter anyway you could put them in serial there would be no need for the relay... as long as one switch satisfies the proper condition then the car will start... i.e. car in neutral or clutch pressed......... It can be done... just test with nothing in front of you lol..... and sitting in the driver seat.
Let us kjnow how it goes...
93nitrousLX is offline
Old 01-01-2008, 10:06 PM
fourfivefour
fourfivefour's Avatar
There are remote start kits that are made specifically for manual shift cars.
You still have to put the car in neutral and apply the E brake.
Get the proper system if the one you have does not specify manual trans and how to connect it.
Do NOT bypass your clutch safety switch!
Do a search in the Audio forum or post a question there. There are guyswho install alarms that hang in there.They may have knowledge of your situation.
fourfivefour is offline
Old 01-02-2008, 11:36 AM
sofob0909
sofob0909's Avatar
waht was that taslk about a hurst shifter????
Old 01-02-2008, 11:45 AM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: PRO50SC
ORIGINAL: Tony71502
Yes, it does!
Oh yes it does! My dad used to have a 4cyl mitsubishi pickup that didn't require the clutch be pushed in to start. I made the mistake of cranking the motor without having my foot on the brake while it was in gear, threw it into the garage door.
That was a little starter half the size of a mustang starter. A mustang starter has about twice as much tq as the one in the mitsu.
Derf00 is offline
Old 01-02-2008, 11:54 AM
bamaroxz
bamaroxz's Avatar
The safety switch mjr46 posted, is it adjustable? Like the switch on the brake pedal for the brake lights? After I installed a new clutch cable I have to push and lift off the clutch pedal for the starter to engage. I have adjusted the cable a few times with no change in the starting. Don't mean to jack your thread, but while we're talkin bout it.
bamaroxz is offline
Quick Reply: CLUTCH PEDAL WIRING????
