Check engine light?
Old 01-02-2008, 06:57 PM
Shelty
Shelty's Avatar
Default Check engine light?
my check engine light came on today when I was about 3 miles from work this morning at around 7 am
it then came on and off every so often on my drive home at 5:15pm....
car has been running fine, engine light just came on, sputtered a tiny bit at idle when I parked
good oil psi
normal operating temps
what could be a possible cause?
I need to change the oil, really close to the 3,000 mile mark
car was really low on gas before I put 10 bucks in it
it was really really cold out today, in the teens...
dirty MAF sensor?
clogged ERG (EGR?) valve?
also, the car sat since friday as I was in no shape to drive after I got my wisdom teeth out, under a cover through two snowfalls
Shelty is offline
Old 01-02-2008, 07:04 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Check engine light?
YOU WANT A GUESS???[&:]....at least do us a favor and run a koeo/koer test and pull a code so we can narrow the 1 of a hundred possibilities down...but when a cel comes on it is often emissions related
mjr46 is offline
Old 01-02-2008, 07:16 PM
Shelty
Shelty's Avatar
ORIGINAL: mjr46
do you have a link on how to do those tests? I cant remember
as as for emissions, no cats and whats prolly filthy O2 sensors
Shelty is offline
Old 01-02-2008, 07:19 PM
Joel5.0
Joel5.0's Avatar
Ask the system, as mj said..... DIY KOEO/KOER/Cylinder Balance Self-Test
Joel5.0 is offline
Old 01-02-2008, 07:21 PM
Shelty
Shelty's Avatar
thanks
I'll have to see if I can give it a shot tomorrow
never did one before and with this bitter weather...
eh, I'll wheel it in the garage, need to replace the lock actuator anyway
Shelty is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Check engine light?
