UPDATE running ritch
Old Jan 5, 2008 | 07:45 PM
93bluestang's Avatar
93bluestang
Default UPDATE running ritch
im not sure but i think my car was and still is running lean instead of ritch lol, not reallly sure... so far i have..... replaced all vaccum lines some were not connected and in the wrong place, next was the TPS, then IAC, then ACT. i got some of my vaccum back now i have power breaks again, the idle is very much inproved, it doesnt stick at a certian rpm any more although right now my only complaint is the idle will still fluctuate up and down at initail start up. and it will not start if its cold i just chanhed the ACT so we will see if that help tomorrow morning. the exhaust still sticks to high hell, Next step its MAF and a Chip. does any one have any sugestions on weird idle?
Old Jan 5, 2008 | 07:53 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: UPDATE running ritch
OK, instead of throwing parts at it, have you had it scanned for codes? Is the CEL coming on also? Seems like you're wasting a lot of money/time and getting no where.
Old Jan 6, 2008 | 10:51 AM
93bluestang
ah very good observation. yea im getting it scanned tomorrow. Hopefully it will throw me some codes.
Old Jan 6, 2008 | 11:08 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you can run a koeo/koer test yourself..no need to go have it scanned..and most likely the guys at autozone will have no clue how to scan it or even have the right scanner....they'll probably try and use an obd II scanner and then tell you they can't pull any codes cause they got no clue which scanner to use and how to even run a koeo/koer test
http://myshifter.com/joel50/EECTEST.html
EZFEED
May 5, 2016 08:54 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
