ECU Removal
Old Jan 6, 2008 | 11:24 PM
OneFastEclipse's Avatar
OneFastEclipse
Default ECU Removal
I'm trying to get my ECU out to install my SCT chip. How the hell does this thing come out of there?
Old Jan 7, 2008 | 08:41 AM
telsonman's Avatar
telsonman
Default RE: ECU Removal
I know in the fox you remove the passenger side kick panel, then unscrew one screw, and it pulls down and out. It was a PITA for me because it was really tight in there.
Old Jan 7, 2008 | 09:01 AM
r.barn's Avatar
r.barn
Easy...... just remove the entire dash and HVAC blower box
You can get to it real easy then ......... lol
or remove the bottom screw on the white plastic ECU holder
and you can try and slide it down and out.
Old Jan 7, 2008 | 09:07 AM
OneFastEclipse
So there is nothing on the top holding the ECU in that I need to worry about?
Old Jan 7, 2008 | 10:00 AM
telsonman's Avatar
telsonman
not that i know of. Mine just pulled straight out. Of course I had to manuever it through the jungle of wires, but thats another story...
Old Jan 7, 2008 | 06:49 PM
94Yellow50's Avatar
94Yellow50
just did two separate sn cars yesterday...panel off, n i unclipped the three separate harnesses that are in front of the ecu to get them outta the way..then hmmm its a metric socket.cant remember which..but ya ..unscrew that screw n pull the plug..then tiny little socket to take off the screw holdin the white plastic deal n it slides out with a little persuasion...oh..to make it even easier..that black metal bracket that the 3 connecters are secured too comes off with two screws..gives ya more room
Old Jan 7, 2008 | 07:17 PM
Milton's Avatar
Milton
ya from what i remember it was just a few bolts folding the brackets nothing on top just needs to be wiggled around abit i thinkk when i did it you kinda pull the bottom end out towards yourself then slide the whole thing down but i only did it once i found getting it back in properly the trickier part
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
rksnow1
Sep 14, 2015 08:46 PM
