HELP coolant leak
HELP coolant leak
on my 95 5.0 i noticed a really small coolant leak i was undre the hood checking fluid levels "wich ended up being low" and noticed a puddle under the car so i jack it up and crawl under and there was antifeeze coolant stting on the wireing harness that sits infront of the block and on the passangerside lower control arm now i cantfind a leak from a head gasket or intake but i did notice where the timing chain cover bolts to the block there is coolant there any ideas from experiance on where this leak could be coming from before i tear everything apart? please help as this is my daily driver and i would hate to have it down for more than a day and well it has 138k on it and ive done everything myslef without a mechanic so far and id like to keep it that way.
RE: HELP coolant leak
Sounds to me like it is coming from the weep hole on the water pump. Btw if its the original pump with a 138k miles on it i can almost 100% gaurantee you its the pump. Let me know if you need repair diagrams if you find it to be the pump ill be more than happy to post them
thanks im really really sure its the timing chain gasket but ill find out n who knows i mean if its the pump ill be able to tell wen i get it off.
thanks for your help ill post what it is wen i get it done "im leaving to go and get the gasket right now.
bradleyb
11-27-2015 07:50 PM
