adjusting roller rockers
alright i duno what is it but im havin a HELL of a time with my rockers...they are 1.6 harland sharp rockers with comp hardened stock length pushrods and ford racing hydr. roller lifters....this is how i am doin it...tell me if im wrong....im tighting both valves in the firing order...then i make sure both are all the way closed...i screw them down to where there is no up and down moved ment in the pushrod then i go 1/2 a turn and lock them down......is that right?
ive heard alot of different things 1/2 turn...3/4 turn...1 full turn? i duno
RE: adjusting roller rockers
Sounds like your procedure is incorrect. You onlytighten downone rocker at a time depending on what stroke (Intake/Exhaust) you are on. I believe it is a 1/2 turn to lock down after you can't spin the pushrod by hand.
