Oil Leak!!!
Oil Leak!!!
I have just discovered an oil leak. Grrr. It's dark out, but it appears to be coming from the right valve cover. How much will cheap replacements cost or should I just attempt to replace the gaskets. If so which ones are some high quality ones?
RE: Oil Leak!!!
Hey, yeah a new set of valve covers would look good, but you will have to take off your upper intake to change them.. I would get a new set of gaskets.. The one's I like are the Fel-Pro cork valve cover gaskets, virtually leak proof... Hope this helps.
bradleyb
11-27-2015 07:50 PM
