Alternator Install Help
I got a new 170AMP alternator. I disconnected the old alternator without really looking at the 2 single wires on the passenger side near the bottom. Do you guys know how those wires are suppose to connect? There's a 3 prong connector on the alternator and 2 single wires.
1. Which wire goes to the top
2. Which one goes to the bottom
3. Which prong connects what
Thanks for the help.
Have you done the 3g upgrade? I dont know of a stock replacement with that high of amperage unless you have rewired for a 3g alt. With the upgrade you will have a 3 prong connector,a single wire that plugs in and a post on the alt. that runs to your batt.
ORIGINAL: FASTBLACK
I need to know which wires plug into the 3 prong connector. There are 2 single wires.
pictures of the products being used would be helpful.. or give me a call ill help u threw it.. 170 huh 3g must have been rewound but heck why not just a 200amp then... either way you lose charing at idle with either rewind job.. 130 more then enough and better performance.
Actually I just looked at the specs and it's a 140AMP not 170.
[IMG]local://upfiles/64185/6C0769DF71534AAEBBD236D393529AFB.jpg[/IMG]
[IMG]local://upfiles/64185/C4D59B4D2BB0449FA6267AD53F0EE556.jpg[/IMG]
