Alternator Install Help
Old Jan 17, 2008 | 02:14 PM
  #21
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Alternator Install Help
Hope this helps.
[IMG]local://upfiles/29779/58FB4B2889A64ED4ADEC487242F385BE.gif[/IMG]
Old Jan 17, 2008 | 09:06 PM
  #22
85stang project's Avatar
85stang project
OK here you go
the long skinny plug has 2 8 gauge wires and one small14 GA wire the two eights are batt postive.... the third is the stator tap which feeds the regulator ... the d plugs as i call it has 3 small 14 GA wires....; one is a 12V key switched source.the other is a light circuit back to the dash and the third is the loop back to the stator plug.. i could make you a repair harness and send directions if you wish......
Old Jan 17, 2008 | 09:07 PM
  #23
85stang project
my advice is kick that old unit out its has a tsb for a stock amperage for fires due to the crappy battery connection and go to the better 3g
Old Jan 17, 2008 | 10:40 PM
  #24
simpsonfan13's Avatar
simpsonfan13
ELEKTRO-FIDE Moderator
From: In Geo-synchronous orbit over redass' bathroom,
here read this walk through it may help
http://www.mustangcentral.net/tech/alternator.html
Old Jan 18, 2008 | 05:53 AM
  #25
bbbngowc's Avatar
bbbngowc
ORIGINAL: 85stang project
OK here you go
I took another picture to show what it looks like. You mention 3 wires ... I only have 2.
[IMG]local://upfiles/64185/884CD8D1094D4C018927A8898926DAB6.jpg[/IMG]
Old Jan 18, 2008 | 03:24 PM
  #26
bbbngowc's Avatar
bbbngowc
Black wire goes to Battery and Blue/Red goes to Stator. It works. No more drain on the battery
mtgldr
Feb 3, 2024 09:00 PM
Golfsito
Oct 6, 2015 11:02 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
