70'S 306 SHORTBLOCK
70'S 306 SHORTBLOCK
Hey guys I found a 306 shortblock from a 70's ford, my question is will I be able to bolt up to my heads and anything different from the 70's block roller non roller etc......???
RE: 70'S 306 SHORTBLOCK
it's a non roller cam block and probably the cam carries a non h.o firing order which will pose a problem for your sefi induction .....cause the injectors are fired in sequence in accordance with the firing order which is a function of the ecm
ORIGINAL: 94 G STANG
i want to use my steeda #19
oh well scratch that idea, im just trying to figure out what im going to do . The heads will arrive tommorow and after taking it to the machine shop and making sure its all good I will proceed to pull out my engine.
I was thinking of just bolting the heads on, its just that it smokes a little and I dont want to end up tearing it out again because of the piston rings. Otherwise it doesnt knock or anything Im also thinking about stroking it and how much [&:], I love this hobby
Daddys Girls GTs
09-14-2015 08:46 PM
