gt/40 intake
I have a '97 Explorer intake in my '65 fastback with EFI swap. Mine is the non-EGR model so I'm not sure how that will work with your current setup unless you eliminated the EGR. About the only 'trick' to it was drilling and tapping for the ACT sensor. The lower in mine doesn't have a boss cast into it by cylinder #5 so I removed a vacuum port in the upper and drilled and tapped it. Do a search on allfordmustangs.com for a nice article on the swap.
Good luck!
Jeff
Good luck!
Jeff
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
